If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
All of sudden both headlight motors start running out of the clear blue, no switch activation or anything. And, when i do activate the headlights, they continue to run for about 5 seconds after the lights are in full up position. Any ideas? Relay, motors, or headlight control module? Thanks in advance for help!
Paul, if the gears are all or part of the problem, there's a good article in The Restorer about replacing them, Volume 43, Number 2, Fall 2016. Good luck.
In the past, Vinnie Peters, Restorer editor, has been kind enough to provide links to past articles. His contact information is on page 2 of the Restorer under "NCRS Officers".
