69 L71 Exhaust recomendations - NCRS Discussion Boards
  • Mark S.
    • April 25, 2019
    • 94
    I have been looking at various exhaust systems (not side) as I complete chassis restoration and would like to know if anyone has suggestions. I would like a top flight when I get this this finished so I want "correct" but not sure I want a rusty system either...
    Mark
    • 43221
    Re: 69 L71 Exhaust recomendations
    Mark
    Mark-------
    It's virtually impossible to obtain a 100% correct system. Even if you could obtain all NOS components, it would not be 100% correct due to the difference in PRODUCTION versus SERVICE rear pipes and mufflers.
    I think your best choice these days would be a Corvette Central system. Keep in mind that 1969 427 originally used a 2" system, the only year big block that did so.
    • Mark S.
      • April 25, 2019
      • 94
      Thanks. I get that. I guess this is virtually the same a ZIP. An aluminized welded system.
      • Chris H.
        • April 1, 2000
        • 837
        • Mark S.
          • April 25, 2019
          • 94
          wow that would be perfect. I live in FL so not sure when i would be up your way. Any thoughts on coming down to the Lakeland regional ?
          • Jon H.
            • January 1, 1999
            • 149
            Mark,
            Corvette central offers an aluminized and carbon steel system. The most accurate system you can buy is from Garner Exhausts:​https://www.gardnerexhaust.com/exhau...ission-system/
            • Tom D.
              • September 30, 1981
              • 2134
              You might have to shorten the CC made header tubes.
              Just to make up for the rear pipes not having a long enough stretched opening.
              Comment based on two separate 65-66 experiences.
              https://MichiganNCRS.org
              Michigan Chapter
              Tom Dingman
              • Mark E.
                • April 1, 1993
                • 4552
                Originally posted by Jon Herrick (31590)
                Mark,
                The original exhaust is double walled with crinkle bends. As Joe said, no replacement system will be as original.
                Mark Edmondson
                Dallas, Texas
                Texas Chapter
                • Jon H.
                  • January 1, 1999
                  • 149
                  I agree. The Gardner is only system that I am aware of that has the crinkle bends on the rear pipes:
                    • 15601
                    [ATTACH=CONFIG]108506[/ATTACH]
                    Hard to say for sure based on that picture, but it sure looks aluminized to me from this distance. If so, that is a 50% deduct right off the bat. Then we will look at the pipes and mufflers. Last I heard there is a configuration issue with the muffler(s).
                    • Jon H.
                      • January 1, 1999
                      • 149
                      The Gardner set can be ordered in carbon steel. There is a 100 upcharge. The mufflers ship separate from what I understand and need to be welded to the rear pipes.
                      • Mark S.
                        • April 25, 2019
                        • 94
                        Thanks guys. I have talked to Gardner and they seem to be the closest thing. I may have some NOS header pipes and can weld the mufflers.
