If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Would a radio delete car have any ground straps at all? My take away from the judging guide suggests not.
This is my first radio delete car and want to make sure some of the details are correct.
If you look at your AIM, section U69 - the radio option you notice that is where the ground straps are added, so none of those ground straps
Check to see if any of the holes (ground strap areas) show any indication of threads - none should exist.
