I moved the radio out of the way on my 63 so I could reinstall the clock. When I went to put the antenna cable back in the AM/FM radio, the male end was broken, oops. I need to replace the antenna cable. In my box of parts I have an antenna cable marked as 63 original. It's solid at both ends.
I looked in the archives without luck. Is there a way to test the cable before I pull the car apart? I put it in the radio and attached a repro antenna, seemed to work ok.
