1963 BW T10 4 spd questions - NCRS Discussion Boards
  • Gary R.
    • April 1, 1989
    • 1798
    A friend just dropped off a early 63 T10 trans for me to go through along with the shifter and linkage.
    I have a few questions I am sure someone can address. I won't get to this for a few weeks so no rush.
    The input has one groove, were these marked the same as Muncies meaning this is a CR trans? It came out of a 340hp swc.
    The shifter is pretty sloppy. We used to toss them and install a Hurst but he would like to reuse this one. Does anyone know of any pictorials showing the break down. I didn't look too close at it yet but there is a pin with a lot of play in it so many I can machine a new pin to tighten it up.
    I believe I saw 2 sets of numbers stamped in the case and a date code on cast in the cover.
    Gary
    • 6942
    • Harry S.
      • July 31, 2002
      • 5305
      Re: 1963 BW T10 4 spd questions
      Try Vette Parts of Michigan for shifter parts. http://www.vetteproducts.net/
      There is another thread running with the Close Ratio Gears for a 340/360 hp 63. https://www.forums.ncrs.org/showthre...-ratio-options
      • Timothy B.
        • April 30, 1983
        • 5186
        Gary,
        The single ring on the input gear for 63 T-10 indicated a wide ratio box.
        Put it in first gear and count the front gear after turning the tail shaft one turn. Wide box = 2.54, close ratio = 2.20
        • Gary R.
          • April 1, 1989
          • 1798
          Thanks guys.
          • Ray K.
            • July 31, 1985
            • 372
            Gary,
            Main Drive Gear tooth count for 2.20 close ratio is 27 teeth.
            Main Drive Gear tooth count for 2.54 wide ratio is 25 teeth.
            Ray
            • Gary R.
              • April 1, 1989
              • 1798
              Thank you Ray.
