Having a bit of an overheating problem in my newly purchased 66 NOM L72 Roadster. The Roadster had a thorough Body-Off about 25+ years ago but as we all know, time can take it's toll on certain things like heater cores, radiators, water pumps, etc.
While freshening things up a bit, I noticed that the 66 dated water pump had the tell-tale leak out the lower weep hole so ordered a replacement pump from RockAuto. Did this about a year ago for a 454 that 'was' in my 65 NOM 396 Roadster and no leak problem with that one. This one now has maybe 40 or so miles on it and it's got a problem with overheating that may or may not be attributable to the water pump but the new pump is leaking, hence the reason for this thread.
One thing I can tell you about the current crop of replacement water pumps is that some of them don't fit. The holes for the hoses are all where they belong and the mating surfaces and attachment bolt holes do line up with the face of the block but, that mating surface is 'fat', no other way to say it. There's just 'too much' meat on the inboard side and I don't think this is a one in a thousand kinda discrepancy because the other RockAuto pump I bought a year ago had the same issue. That extra wide casting interferes with the stock stamped timing cover to the point where it will not sit flush unless you get out the grinder and remove about a good 1/8+ of material from that inner edge. That pump has a familiar name brand as it was a Gates 44088 but I believe it's made overseas
Once both pumps were 'ground down', they did fit. For the short period of time that the 454 was still in the 65 Roadster it worked okay and no leaks. I have about 40 or so miles on the new/modified Gates Pump and it's already leaking out the lower weep hole.
So, my question is this...does anyone offer a USA made casting Short Bigblock Water Pump? Names I've heard tossed about in various threads over the years include Edelbrock, Flowkooler and Stewart but I haven't read anything recently that says the castings are new or made in this country or that the internals are made here either. Actually I have read some complaints regarding Flowkooler that talks about the same problem with fitment.
And, if I decide to put a rebuild kit into the old 66 casting water pump that had been on there...are the water pump rebuild kits worth the effort and are they also made overseas?
I am aware of some businesses who offer rebuilding services, I prefer to do the work myself.
