1967 small block factory engine pad grind out
  • Paul S.
    • July 1, 1982
    • 351
    Does anyone remember an article a long time ago about some late 67 small blocks with the pads ground out and restamped. I think because it was the end of production and gm had a short supply of motors ? I believe it was in the driveline . I'd like to get a copy of the article .
    Thanks for any help !
  • Mark F.
    • August 1, 1998
    • 1394
    Re: 1967 small block factory engine pad grind out
    Originally posted by Paul Schuster (5739)
    Does anyone remember an article a long time ago about some late 67 small blocks with the pads ground out and restamped. I think because it was the end of production and gm had a short supply of motors ? I believe it was in the driveline . I'd like to get a copy of the article. Thanks for any help !
    Hi Paul,
    I do not have a copy of this Restorer issue and therefore have not been able to look at the article, but maybe this is what you were remembering?
    PS - this is from the Restorer Index page under Services > Publications > Restorer Index at the top of the TDB page
    FACTORY ENGINE PAD REGRINDS Volume 22 Issue #3 WINTER 1996 by Mike Antonick
    the link below is only provided so you can see what was on the front cover...
    https://www.ebay.com/itm/Vol-22-No-3...-/371919295741
    thx,
    Mark
    • Mike E.
      • March 1, 1975
      • 5106
      Attached are scans grind out article (1).jpggrind out article (2).jpggrind out article (3).jpggrind out article (4).jpggrind out article (8).jpggrind out article (9).jpggrind out article (5).jpggrind out article (6).jpggrind out article (7).jpgof that article. A couple of the pages jumped around on me, but I think you will be able to follow it.
      • Harry S.
        • August 1, 2002
        • 5187
        Send an email to Vinnie Peters, Restorer Editor. He should have a PDF copy available.
        • Jimmy G.
          • November 1, 1979
          • 968
          It happened more times than people would like to admit to. I have a 1965 396 with documentation of being a grind out. There are many examples.
          • Edward B.
            • January 1, 1988
            • 537
            Very interesting and detailed article. Thank you for reproducing same so we did not have to dig through a pile of past issues.
            • Paul S.
              • July 1, 1982
              • 351
              Thank you for the help
              • Richard L.
                • November 1, 1984
                • 168
                Yep, it's all true. My #22491 (July 5, 1967--see RESTORER, Vol 25, No 1, Summer 1998) 67 roadster has such an anomalous ground factory stamping. As Jimmy Gregg points out above, there are more than a few such examples (twenty-some?), which makes us owners of these cars not such an exclusive club!
                Ric
