Copper rear end tongue nut - NCRS Discussion Boards
  • Joseph A.
    • June 20, 2012
    • 136
    What years used the copper nut on the rear end tongue bolt?
  • Gary B.
    • February 1, 1997
    • 7077
    Re: Copper rear end tongue nut
    I believe that GM #9424985 nut was supposed to be used from 1967 through 1979 (or ‘82?). But I found one on my July build date ‘66, so it appears someone jumped the gun with using that copper plated nut.
    Gary
    • Joseph A.
      • June 20, 2012
      • 136
      I do not believe 9424985 is copper flaashed. My standards book states this nut is not copper flashed. I believe the copper nut is from 63 to possibly 65
      • Gary B.
        • February 1, 1997
        • 7077
        Joseph,
        Are you sure?
        In a 2019 posting Joe Lucia stated “…GM #9424985. The latter, which was used in PRODUCTION for the front differential mount application for 1967-79 Corvettes was a heavy hex (11/16" across-the-flats), 3/8" thick, 301M material grade, and of COPPER plating.”
        David Bartush added: “
        GM #9424985 7/16-14 GM 301-M steel copper (finish) Class 2B thread
        "GM 301-M: Nuts of this material are intended primarily for assembly with bolts conforming to GM 290-M or GM 300-M steel."
        "Finish: Copper on steel: GM 4250-M Code OY, specification shall apply. It requires a flash deposit of copper by immersion coating or electroplating for identification or coloring."”
        The nut used from 63-66 is given in those AIMs as GM 3765425, which was Gr 8 and likely either natural or cad/zinc.
        If you check thru PartsVoice, it looks like there are several GM dealerships that still have a few example of 9424985, even though it is GM-discontinued.
        Gary
        • Joseph A.
          • June 20, 2012
          • 136
          You are correct I found another standard parts book that stated they are copper.
