67 Small Block Exhaust Manifold French Locks - NCRS Discussion Boards
  • Bill L.
    • April 1, 1985
    • 349
    Hi:
    Some time back I was having my white 67 small block coupe (300HP) judged and I got dinged for the french locks.... apparently, they are supposed to have a "B" stamped on them. At the time mine did not....
    I remedied the situation and the subsequent judging process resulted in no issues....
    I checked the new 67 manual and the French locks are mentioned but not the "B" stamping....
    See the photo....
    Any verified experience with this from a judging perspective would be appreciated ....
    Thanks!!
    Bill
  • Gary B.
    • February 1, 1997
    • 7078
    Re: 67 Small Block Exhaust Manifold French Locks
    Bill,
    Have you seen this posting? https://www.forums.ncrs.org/showthre...+locks+exhaust
    Regarding the squared vs rounded tab shape in that old posting, I believe it depends on BB vs SB during the C2 era.
    Gary
    • Bill L.
      • April 1, 1985
      • 349
      Thanks Gary...no I did not see that post.....but just read it....interesting for sure...
      I did not see anything mentioning the square vs. round tabs on the French locks...nothing for big vs small block in the 67 manual (unless I missed it)....
      It does however, bring up the issue of "vendor stamps" on a particular part....
      I know that for some time (and maybe they still do) Paragon stamped a "P" on various parts ("usually" out of sight ---but NOT always) so that people could not return an inferior competitors part for a credit.... Different subject alll together..... I know of two parts in particular that have "P" stamps on them and Paragon has admitted that one of those stamps stamps is in fact theirs. I suspect that the second one is as well .....but that is not verified.
      Where I am going here is that there is no call out of the stamps on the French locks....tab configuration nor letter stamp.....maybe we can get this sorted out!!! Sure hope so!!
      I have a second in-bound 67 coupe due here in June and I want to get the detail right.....
      As always.... Thanks & Best Regards
      Bill
      • Gary B.
        • February 1, 1997
        • 7078
          • 43289
          Bill
          Bill------
          There were several part numbers for the small block exhaust manifold french locks over the years. GM #3733122 was used from 1956 to ABOUT 1963and discontinued from SERVICE in January, 1965. GM #3841091 was used from ABOUT 1963 to ABOUT early 1966 and discontinued from SERVICE in October, 1966. I know nothing regarding nuances of configuration of these 2 part numbers. Sometime in the 1966 model year the part number became GM #3880844 and this continued through 1981. The latter is configured like the one shown in your first picture and with the "square" locking tabs. These often have a "B" stamping but I don't know that all did. I'm quite certain that the "B" is a manufacturer's ID mark and considering the fact that Chevrolet was using these things by the millions, there may very well have been more than one manufacturer.
          By the way, the GM #3880844 was discontinued from SERVICE in July, 1987 and replaced by GM #14081241. The latter have ROUND locking tabs and 3 small "tits" along their length. Sometime later these were discontinued and replaced by GM #12338135. These are identical to the 14081241.
          • Jimmy G.
            • November 1, 1979
            • 977
            Agree with Joe. I have 30 or 40 originals and cant find a stamp on any of them.
            • Brian M.
              • February 1, 1997
              • 1842
              Was there a deduction taken?
              • Gary B.
                • February 1, 1997
                • 7078
                Brian,
                The relevant line item in the Mechanical judging sheets includes “Bolts, studs, nuts, flanges, locks, washers, & heat riser”. With a total of 5 originality points. With a configuration (or completeness?) issue for the B stamping with the French locks, it’s hard to imagine that would be worth more than 20% of 1 pt. If a deduct was taken for a missing B stamping, I would ask the judges to explain their math.
                Gary
                • Bill L.
                  • April 1, 1985
                  • 349
                  Thanks Joe ... my sense is to stay with the stamp....
                  Regards
                  Bill
