Question on the 1966 Technical Judging Manual- 1966 Production Calendar
  • Joseph I.
    Infrequent User
    • April 20, 2021
    • 18
    On the 1966 Technical Judging Manual- 1966 Production Calendar(page #210) there are production numbers on each day.
    Is that number the last production number produced on that day? IMG-4744.jpg
    Thank You!
  • Dan A.
    • June 1, 1974
    • 1072
    Re: Question on the 1966 Technical Judging Manual- 1966 Production Calendar
    I believe it is the last number started that day. The car may not have been finished until the following day
    • Gary B.
      • February 1, 1997
      • 6851
      Joe,
      Yes. You can figure this out if you look at Sept 1, 1965, the first day of the ‘66 model year production, where you’ll see the number 98; 98 cars produced that day. And if you look at July 29, 1966, the last day of production you’ll see the number 27720, which ‘66 experts will tell you was the VIN derivative of the last ‘66 produced.
      I just checked the birthday calculator on the C2 Corvette registry website. For the ‘66 model year, if you type in VIN 00001, it says the birthday is Sept 2. If you type in VIN 00098, it says the birthday is Sept 3. This suggests that Dan might be correct. And if you type in VIN 27720, it says July 30. So, now I’m definitely confused, and it appears I don’t know what I thought I knew. Not the first time that’s happened.
      If ‘66 VIN 00001 wasn’t born until Sept 2, I’m not sure of the value of the production calendar in the JG if it says Sept 1. Unless the day a car was started being built is more important than the day it was finished.
      Gary
      • Joseph I.
        Infrequent User
        • April 20, 2021
        • 18
        Thank You Very Much.
