If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Ok - next question
Can a 67 or 68 with a 327 block - fuel pump be fitted to a 63 327 block - ? then I can use an aftermarket / different year fuel pump while I get mine re built ?
Hope that makes sense - My 63 is a 300 bhp
As always any help much appreciated - Thanks Keith
It is my understanding the fuel pump mounting boss did not change on the 327 from 1962-1969 during the entire production run. So yes, the fuel pump should fit your engine. Joe Lucia can probably confirm.
Ed, your certainly right about the fuel line but easily overcome by a temp fuel line as well… But i agree, a fuel pump that fits the car on Rock Auto is $11.00. Thats a no brainer! Quit thinking about it and move on.
