65-66 Telescopic steering column distance from dash
  • Jeremy R.
    • May 24, 2012
    • 137
    Could someone with a 65-66 telescopic steering column installed in their car tell me the measured distance between the end of the directional housing closest to the dash and the steering column when the column is in its closest and furthest positions? Thanks
    • September 16, 2008
    • 6939
    Re: 65-66 Telescopic steering column distance from dash
    Jeremy, does the AIM show what the setting /distance? I think that you can just set it according to what you feel is comfortable. Since it does have some adjustment.
    • Jeremy R.
      • May 24, 2012
      • 137
      AIM doesn't show anything that I could see in the telescopic page, and the standard column only says that the end of the shaft on goes halfway into the that side of the rag joint.
      • Elliott P.
        • February 5, 2018
        • 65
        • Jeremy R.
          • May 24, 2012
          • 137
          Thanks Elliott. Someone else also gave me the same measurements, so I think its safe to say those are good values.
          • Don H.
            • December 1, 1981
            • 1469
            Jeremy, I just measured mine and it is 7/16 in and 3 1/2 out (measured on the bottom). Don H.
            • Jeremy R.
              • May 24, 2012
              • 137
              I did finally find in the Service Manual where it called out a distance of 0.06" from the lower end of the directional housing and the collar when reinstalling the column.
