I could use some help on identifying my 67 Rear end stamped AM 2 1 67. The car is a very stock 300HP A.I.R. 4 speed car. My confusion is that it is obviously a 3.70 ratio but stamped AM 2 1 67 that correlates with my mid Feb build 67. However AM rear end is noted as a 3.36 posi manual trans in John Amgwert's 53-67 Specification Guide. Not sure if "manual trans" means 3 speed? My 4 speed is stamped with correct VIN and corresponding date P7 A 23.
I'm pretty sure that this is the original carrier but definitely not 3.36 and not sure if it's open or Posi? jacking up one wheel it turns that implies Open but it could be a Posi with worn synchros? Doubt that anyone would change a 300 HP grocery getter from a 3.36 to 3.70.
Could it be mis-stamped at the factory as a 3.36 3 speed car? Want to change to 3.36 open or posi soon.
Any help greatly appreciated! John
