If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Hi all. I just bought this service replacement AC RC-6 cap and am wondering if it should have a gasket where the bottom side of the cap interfaces with the top of the radiator neck.
No gasket where the bottom side of the cap interfaces with the top of the radiator neck. The seal is made at the bottom of the radiator neck with the lower gasket. Technically, the spring is pushing up on the cap and the tabs keep it retained. A gasket here would/could interfere.
