65 grille markings "D & L, can not find?
  • William B.
    • May 1, 1975
    • 935
    I have what I believe an original 1965 grille. I am reading the 65 judging guide and it explains that the manufacturers stamp of
    D&L should be on the passengers side top? I can not find any markings on mine.
    Was this stamp on all 65 grilles or am I looking in the wrong area? Can anyone show me a picture of the location?
  • Don H.
    Moderator
    • June 17, 2009
    • 2200
    Re: 65 grille markings "D & L, can not find?
    Here you go Bill. Look hard to see it along the rear edge. This is the passenger side top. And when I have seen it on a 65 grille, it is stamped at least once more, perhaps 15" over. I've inspected many 65 grilles judging EXT, and I almost never see one with the stamp.
    • Kent S.
      • February 1, 1993
      • 199
      Don - thanks for the tip. The D&L's are right where you said they are on my '65. Never found them before.IMG_0989.jpgIMG_0990.jpg
      • William B.
        • May 1, 1975
        • 935
        Don, picture attached, no DL, I believe this grille is original to my car, is the judging manual saying all cars should have this marking?
        • Don H.
          Moderator
          • June 17, 2009
          • 2200
          Bill,
          That's what the 'guide' implies, but we both know the guide doesn't know everything. I think my 65 has its original grille, and there is no stamp. And as I said, I've looked at dozens if not 100s, and seldom see one with the stamp. I don't believe they all had it, and I don't deduct if I don't see it. I should add that I've heard it can be on the sides of the grille too. I can't see there when the grille is installed. Did you happen to check there too, Bill?
          (you're welcome Kent,,,)
          ps, I have to say Bill, that grille is awfully pristine to be an origie piece. Must be a low miles, well kept 65?
          • William B.
            • May 1, 1975
            • 935
            Don, Thank you for responding, I have been looking all over, no DL, trying to get it polished up because I do not think it was ever replaced.
            • Stewart L.
              • March 1, 1980
              • 350
              • William B.
                • May 1, 1975
                • 935
                This is from my 396 with 32k miles, I am finishing the restoration up, never wrecked all original, that's why I questioned the D L markings, I am assuming they were not all stamped. It is a local car I know the history from day 1.
                • Gary B.
                  • February 1, 1997
                  • 6861
                  • Don H.
                    Moderator
                    • June 17, 2009
                    • 2200
                    Gary,
                    Bill is probably in the garage, working on his 396, so i'll show you what it says. Obviously it needs a touch of revision (we're working on that now).
                    • Gary B.
                      • February 1, 1997
                      • 6861
                      Originally posted by Don Hooper (50543)
                      Gary,
                      • Dennis C.
                        • August 1, 1989
                        • 44
                        My 65 built last week of Dec 64 has the D&L marking .
                        Dennis.
