What lube for C2 4-spd shifter ?
  • Wayne M.
    • March 1, 1980
    • 6414
    R & R' ing my '65 4-spd Muncie shifter assembly {the one that bolts to the rear of the tail shaft housing with the chrome shifter sticking through the console}. The levers ( 1st & 2nd; 3rd & 4th, and reverse) had high resistance sliding past one another. Discovered a sandy residue with some hardened oil/dirt coating in some places. Cleaned them up with lacquer thinner and now ready to install. What did the factory use (nothing ?, bearing grease ?, oil ? [similar to gear box], motor oil] ?
    • 11535
    Re: What lube for C2 4-spd shifter ?
    white lithium grease
      • 43129
      Wayne-----
      I'd use GM #12377985, an all purpose chassis lube. This is a great lubricant to have around as it serves many chassis lube purposes except front wheel bearings.
      • Larry M.
        • January 1, 1992
        • 2683
        What I have used for over 25 years (and no issues). May not be the best, but it works, and is what the factory guys used.
        Larry
        • Mark E.
          • April 1, 1993
          • 4456
          The 1970 Service Manual (I don't have one for 1965) specifies EP chassis lube for shift linkage.
          Mark Edmondson
          Dallas, Texas
          Texas Chapter
            • 43129
            Larry
            Larry------
            Lithium grease will work OK but I do not think it's the best thing to use. For one thing, I have NOS shifter assemblies and the lubricant on them is definitely not white lithium. It appears much more like chassis lube. In addition, EP chassis lube has a greater film strength than white lithium grease. This will produce better lubrication over a longer period of time than white lithium.
            • Mark E.
              • April 1, 1993
              • 4456
              The Chassis Manual says "Every 6000 miles or 4 months lubricate shift linkage and on manual transmission floor controls lever contacting faces with water resistant EP chassis lubricant..."
              What's a good method for doing this? Once in awhile I clean the linkage with brake cleaner then push in grease with my hands. Is there a better way?
              Mark Edmondson
              Dallas, Texas
              Texas Chapter
