'71 LT1: AIM Request - NCRS Discussion Boards
  • Ray K.
    • April 30, 2005
    • 409
    Would someone be kind enough to post copies of their 1971 LT1 radiator and radiator shroud assembly manual pages?
    Looking thru my assembly manual, I'm missing the radiator (copper) & shroud (fiberglass) pages.
    Pages are probably in UPC LT1, Sheets B1 thru Bx . . . . .
    Appreciate any help in posted the pages . . . .
    Ray K (#43777)
  • Mike E.
    • February 28, 1975
    • 5141
    Re: '71 LT1: AIM Request
    Ray,
    At the top of page LT1 A2, it says; "The following components are not illustrated in this R.P.O."
    At the bottom of that category,"UPC 13 Radiator and Radiator Grille", it mentions "radiator assembly and radiator shroud".
    I deduce from that that you aren't going to find any sheets with those on it.
    • Ray K.
      • April 30, 2005
      • 409
      Mike,
      Thanks for your input . . . I had seen the not illustrated on UPC LT1 sheet A2 and the radiator and radiator grille info in UPC 13. I was hoping that there was a later change to the AIM that might be available. I only wanted the AIM sheets in order to reference & illustrate how my "original owner" '71 LT1 was built (and agree with what is identified in the 6th Edition Technical & Judging Manual. One only has to wonder why the LT1 copper radiator and plastic shroud wasn't documented correctly in the AIM. . . . . .
      Either way, thanks again . . . .
      Ray K
