If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
396 LH Valve Cover - no depression for Brake Booster?
Re: 396 LH Valve Cover - no depression for Brake Booster?
If the temp sender clips are on the bottom it’s for a 68-70. As they stoped using chrome on pass starting in 71. If no clips I would think it’s a repro
IT's for 69 Chevelles and full size. 68 IS THE SAME COVER MINUS the temp wire clips because 68's had their alternators on the same side of the engine and the temp wire was part of the alt harness, it draped over to the sender.
IF the plug wire stand were to be on the other side of the top hole for the valve cover bolt the application would be Nova and Camaro the engine is much closer to the wiper motor on these two models so the wire stand is in front of the last Hole to give more clearance for aforementioned motor.
