Installing tunnel insulation with transmission and shifter in place- C3 - NCRS Discussion Boards
  • Mark E.
    • April 1, 1993
    • 4603
    The exhaust project continues to grow- replacing the exhaust led to repairing the battery box (dusty job), which led to cleaning the floor pan (messy job), replacing battery cables (harder than it sounds with these cars), which now leads to the prospect of replacing the tunnel insulation.
    Questions:
    - Can the insulation be installed with the 4-speed and shifter in place? What if the opening for the shifter is cut down the side so the insulation can be rotated around, up and in place? Other methods?
    - Another thread mentioned that aftermarket insulation differs in stiffness. Some are more pliable and hence more easily installed. Any particular source recommended?
    - What's the purpose of the small hole on top near the front (see photo)?
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
  • Mark E.
    • April 1, 1993
    • 4603
    Re: Installing tunnel insulation with transmission and shifter in place- C3
    Closing this out: I ended up installing new tunnel insulation by cutting it from the shifter opening to the left outside edge, then slid it in place by rotating it around the transmission from the right side. The cut was then sealed with Reflectix foil tape which matches the underside of the insulation. The tape is not noticeable unless you look for it.
    The exhaust was removed which made the job easier. I used this opportunity to clean the underside of the tunnel and transmission case, then also installed a new foam collar around the bellhousing.
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • Larry M.
      • December 1, 1986
      • 541
      Mark,
      I've been looking at the tunnel insulation on ours and thinking of replacing it. Which vendor did you get yours from? And did the reason for the hole become evident?
      Larry
      • Mark E.
        • April 1, 1993
        • 4603
        I sourced the insulation from Paragon because it was on sale at the time. It fit fine and didn't have the small hole I wondered about.
        Mark Edmondson
        Dallas, Texas
        Texas Chapter
        • Larry M.
          • December 1, 1986
          • 541
          Thanks, Mark!
          • Bob W.
            • December 1, 1977
            • 802
            Mark, Did you find out what is the purpose of the small hole?
            • Mark E.
              • April 1, 1993
              • 4603
              I'm not sure, but I don't think the replacement insulation had that small hole. I need to crawl under to refresh my memory. So I'm not certain if originals have that hole or not.
              Mark Edmondson
              Dallas, Texas
              Texas Chapter
              • Justin S.
                • July 3, 2013
                • 305
                Would the whole be for the emergency brake cable?
                • Larry E.
                  • 1692
                  Mark: How did you secure it to the "Tunnel" or just let it hang there. If so does it not move around a bit? Larry
                  Larry
                  LT1 in a 1LE -- One of 134
                  • Mark E.
                    • April 1, 1993
                    • 4603
                    I'll check the next time I'm under there. Meanwhile, maybe a real expert will tell us.
                    Mark Edmondson
                    Dallas, Texas
                    Texas Chapter
                    • Mark E.
                      • April 1, 1993
                      • 4603
                      There are four sets of retaining tangs riveted to the floor. Straighten them, position the insulation, poke them through the insulation, then bend them back.
                      Mark Edmondson
                      Dallas, Texas
                      Texas Chapter
                      • Mark E.
                        • April 1, 1993
                        • 4603
                        I looked under the car but could not see why there would be a small hole on the top of the insulation near the front driver's side. The battery and speedo cables are on the passenger side. The reverse lamp wiring is on the driver's side but it has its own clip on the floorboard.
                        As mentioned before, unlike the photo in my original post the replacement insulation didn't have this hole. Google search images show replacement insulation with and without this hole.
                        So the mystery continues.
                        Mark Edmondson
                        Dallas, Texas
                        Texas Chapter
                          • 15621
                          Could it be for the wires for the kick-down on the TH400? Just a question, as I have little experience with a TH440 in a Corvette, yet.
