I am having trouble finding a fitting for the schrader valve on the low side (Dryer). My normal A/C Gauge Hoses have a 45 degree bend that connects with the dryer schrader valve for the low side NORMALLY but, it just misses connecting to the valve because the cooling coil box is to close so, the hose fitting is just blocked.
I tried using a schrader 45 degree coupling but it has even less clearance. It is an original dryer unit with the valve pointing directly at the cooling coil box about 5/8" clearance.
Would appreciate any thoughts/suggestions. Trying to keep it original. I do know, it could be charged off the high side.
