Transmission Speedometer Gear - NCRS Discussion Boards
  • Richard T.
    • February 1, 1979
    • 858
    Can someone tell me the correct color and tooth count for the nylon transmission gear that drives the speedometer for the following rear end ratios? 3:36, 3:55, and 4:56. T-10 and Muncie Thanks
  • Patrick B.
    • August 31, 1985
    • 1996
    Re: Transmission Speedometer Gear
    Based on my recent questions about this topic, I would say that the 3.36 would use the red gear with the large 8 tooth output shaft gear;the 3.55 would use the silver gear with the large output shaft gear or the green gear with the small 8 tooth output shaft gear; the 4.56 would use the steel (not nylon) pencil gear with a rare 6 tooth output shaft gear. The 3.55 is the only rear for which pencil gears are available for either size of output shaft gears, and the same combos are used for 3.70 rears because the error is not too great. If you don't want to disassemble the transmission to change output shaft gears, there are speed changing adapters available. These combos apply to most Muncies up to about 73, with the 68 and up using plastic output shaft gears with their own color codes. These combos would represent the original equipment tires which have about 775 revolutions per mile. 775-15, F70-15 and 215/70R15 tires are all close to 775 rev/ mile.
    • Terry D.
      • May 31, 1987
      • 2692
      • Patrick B.
        • August 31, 1985
        • 1996
        Terry -- That is an interesting table, Joe Lucia and other sources I found said that pencil gears with fewer than 22 teeth would not mesh correctly with the 1.76" drive gears. Have you tried any of the smaller driven gears with the 1.76 drive gear?
        • Joseph L.
          • July 26, 2012
          • 162
          Hi Richard
          The topic and calculations are covered in the SoCal February 2020 newsletter.
          You also need to know the tire diameter and which drive gear is installed in the transmission.
          Joe
            • 43221
            Richard------
            It depends on year model, tire size ,and installed transmission DRIVE gear. The transmission DRIVE gear can be inferred by knowing which DRIVEN gear is now installed.
            • Gerald C.
              • June 30, 1987
              • 1283
              I have 3:55 gears and the 6:70-15 Bias Ply tires on my 63 car. So.....If I interpret this chart correctly, I can use the red 21 tooth gear for either diameters of drive gears of 1.76 or 1.84 that I might have in my tranny. It looks like just different part numbers.
              Thoughts??
                • 43221
                Thoughts??
                Gerald------
                The 21 tooth driven gear is only compatible and designed for use with the large (1.84") drive gear.
                • Harry S.
                  • July 31, 2002
                  • 5305
                  I know tires and other items will cause the speedometer to be off. But the day the car was produced this is what I recall.
                  63-67 GEAR - speedo drive in transmission, 3:08, used w/3:70 - 4:11 rear end gear ratios, (18 tooth, brown)
                  63-67 GEAR - speedo drive in transmission, 3:36, (20 tooth, blue)
                  63-67 GEAR - speedo drive in transmission, 3:55, (21 tooth, red)
                  63-67 GEAR - speedo drive in transmission, 3:70, (22 tooth, green)
                  63-67 GEAR - speedo drive in transmission, 4:11, (24 tooth, yellow)
                  • Gerald C.
                    • June 30, 1987
                    • 1283
                    Joe,
                    Thanks for this information. Making the assumption I have the smaller 1.76" gear, what tooth count would you recommend? The speedometer is not registering at all. It does when the cable is driven by a drill, so I know it's in the tranny/plastic speedometer gear set-up.
                    Jerry
                      • 43221
                      Joe,
                      Jerry
                      Jerry------
                      If you do have the 1.76" drive gear installed and you do have 3.55:1 rear gears, I'd say try a 22 tooth GREEN gear. That's the lowest tooth count gear that's compatible with the 1.76" drive gear. I don't think it will give an accurate speedo reading but it should drive the speedometer.
                      • Gerald C.
                        • June 30, 1987
                        • 1283
                        Thanks Joe. I have a green 22 tooth and I'll try that. But having the 21 tooth red in there now will prevent the speedo from even registering??
                        Jerry
                        • Donald O.
                          • May 31, 1990
                          • 1588
                          Joe,
                          Jerry
                          Is this a new cable, new issue ?
                          • Joseph L.
                            • July 26, 2012
                            • 162
                            Hi Jerry
                            As Joe Lucia said, IF you have a 1.76" dia. drive gear installed, a 22 tooth green 0.870" dia. driven gear will get your speedo registering, or you have other problems. A 22 tooth green is what usually come with a 3.70 and 1.76" drive gear.
                            A 21 tooth red 0.810" dia. driven gear may not mesh with a 1.76" dia. drive gear. There may be no reading. A 22 tooth green 0.870" dia. driven gear, may be one tooth greater than that red gear, but is not in the same gear family. They do not work.
                            Think of it this way: Replace an M21 first gear into an M20 gearbox. Change nothing else.
                            Joe
                              • 43221
                              Jerry
                              Jerry------
                              Well, if you have the 1.76" DRIVE gear installed, the red 21 tooth DRIVEN gear MIGHT not mesh with it. However, I would think there would be enough "interaction" that you would get some kind of speedometer needle movement.
