Does anyone have insight into how I can determine the cold valve lash settings for a '63 340HP without knowing what cam was installed during a previous rebuild?
In my absent-mindedness back in 1990 when the motor was re-built, I did not get a blueprint and cannot find on the receipts where a new cam was purchased (I do see new pistons, etc. as it was bored .030 over). In my current day absent-mindedness, I didn't think of this before the shop installed the motor and trans. I have the Corvette Specs book that shows hot valve lash settings of .008/Intake and .018 Exhaust but did not see a cold setting.
Other than busting the budget even further by removing the water pump and timing chain cover to view numbers on the front of the cam (hopefully), I don't know of a correct way to set them properly other than making a guesstimate using the latest revision of the Hinckley-Williams doc on settings. They stated a setting of .008/.015 and that there was not that much difference in the hot vs cold settings given the heat retention nature of the iron block and associated hardware. On the side of caution, I'm thinking of adding .002 to the original factory settings cold and then backing down to .008/0.16 hot. These only work, of course, if it's a stock cam.
Thoughts? (Please keep it simple - lots to learn about lift, degrees, indexing, etc.!).
Fred
Fred
John
