If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
I'm rebuilding a 1970 LT1 steering column, it seems from my observations that the (shaft) lower bearing retaining clamp was not used in 1970. However I have pictures of a Bowtie July built 1970 LT1 with a original lower bearing clamp.
So was there a lower clamp used in July built 1970 LT1s?
Hi Gary, mine is a standard column and the photo I posted is anyone's guess as I didn't take the photo and I do not want to post the serial # of that car..
