If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
The NOS 3741428 valve shown in the photo below is listed in my vintage Chevrolet parts catalogs in Gr. 8.866 as for all models with 3/4" hose and described as "VALVE ASSY, water shut-off (hose insert type)". Was it ever original equipment on any specific Chevrolet or GM model or was it a repair part you added because you could not shut off your heater in the summer time?
Dave
our 54 vin 2184, had an identical valve when i bought the vet i 1970. i don't judge 53-55 very often, but i've seen valves such as this on most i've judged. the container u show looks like 1970's-80's vintage parts boxes. mike
Thanks Mike. I assume the valve is attached to the water pump.
Back in the 1970's when I owned a 1970 Camaro SS350 I spliced a similar aftermarket non-threaded brass valve in one of the heater hoses to completely shut off the heater during the summer months.
Dave
