66 L72 cylinder case question - NCRS Discussion Boards
  • E S.
    • December 29, 2008
    • 451
    Hi all- Just received my 66 TIMJG, noticed picture M 2-3,pg. 99.
    Looks completely different than mine-I have fairly early car (3795)-maybe a e/p or l/p thing?
    or maybe a mirror image?-my car is unrestored,and very original-Here is a pic of the block above the oil filter.IMG_20200227_215131907.jpg
  • Dan A.
    • May 31, 1974
    • 1074
    Re: 66 L72 cylinder case question
    Looks like the negative for the photo on page 99 is in front to back or vice versa.
    • Jack M.
      • March 1, 1991
      • 1163
      Dan- I believe you are correct... the photo in the JG appears backwards.
      The upper circle for the AC logo should be on the left side... not the right side.
      • E S.
        • December 29, 2008
        • 451
        Strange-I do know that this is an important area of the 3869942 case, to indicate 2 bolt or 4 bolt main bearing caps. I would like to hear from other members too. I have included information from Alan Colvin's "Corvette by the numbers" Corvette drivetrain parts reference publication.IMG_20200321_202833779.jpgIMG_20200227_215131907.jpgIMG_20200320_171923540.jpg
        • Jack M.
          • March 1, 1991
          • 1163
          E J - Not sure if you were following my thoughts... take a look at the image below.
          The AC logo is in the WRONG location, backwards in the JG.
          So the image in the JG appears to be accidentally REVERSED.
          • Don H.
            Moderator
            • June 16, 2009
            • 2262
            Good catch EJ. And Dan and Jack for clarifying the publisher error. The photo went to the publisher correct, but was reversed when the book went to print. I have made Bill C aware, and he said he appreciates the catch.
            • E S.
              • December 29, 2008
              • 451
              Hi Jack- Thanks for your input- I was concerned about the location of the provisions for the oil galley (oil pressure gauge),and possible oil cooler; that was depicted in the TIMJG, as this is a critical area of the 3869942 to determine whether it is in fact a 2-bolt or 4-bolt main bearing block.
              Thanks again-E J
