If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Looking for details on the phillips head screws that attached the two halves together on the 3 piece distributor shield.
How long, head diameter, etc.
A GM part number would be great.
Thank you ,
Bill
Bill-------
The GM Part number was 163162. However, it was never available in SERVICE.
I have some of these on my original shielding but I can't get at it right now. As I recollect, the screws were self-tapping, pan head phillips. I believe they were size 6 but I'm not sure. They were short-----maybe 1/2" to 5/8" and were zinc plated.
If you use a screw that is longer than the original length, the longer screw will hit the distributor housing beneath the plate and prevent the plate from moving. I had this happen.
Jim------
Yes, you're correct regarding the internal 2 piece RF shield used to shield the points and condenser for 1970-74 Corvettes. However, I believe the original question involved the screws on the 3 piece shield on radio-equipped Corvettes which surrounded the distributor for RF shielding. That shield was used for L1969-E1970.
