Repainting P02 wheel covers -- any advice?
  • Paul S.
    • October 30, 2015
    • 203
    Hi all,
    I am restoring a set of P02 wheel covers for my '69 convertible. They are now perfectly dent-free and polished, so it is time to repaint the black areas.
    I am wondering if anyone who has done this before can share any advice. I am especially curious about masking methods for the fins, as I want to maintain the rounded ends on them, but that is going to be difficult.
    ​​​​​​​Paul
  • Ron G.
    • December 1, 1984
    • 861
    Re: Repainting P02 wheel covers -- any advice?
    Paul,
    I personally have tried and researched restoring PO2 wheel covers, and in my opinion it would be very difficult to replicate the areas where they are painted black. I do believe they were painted with lacquer and it could be done with someone who possesses a lot of patience. I do not know of anyone at this time who is restoring PO2's. - Ron
    "SOLID LIFTERS MATTER"
    • Paul S.
      • October 30, 2015
      • 203
      Well, I decided to attempt it and just finished my first one last night. It turned out pretty much perfect if I do say so myself. Since I plan to have my car judged, I really needed to make them look exactly like original. This makes the fins on the lower (outer) piece of the wheel cover MUCH harder to mask-off. If you are not doing an NCRS-restoration, you could just extend those into the outer polished rim, as I have seen others do. Instead, I masked them each individually, which obviously took a ton of time. Anyways, on to the pics...
      BEFORE:
      DISASSEMBLED, STRIPPED, POLISHED, & AREAS TO BE PAINTED ROUGHED-UP:
      • Paul S.
        • October 30, 2015
        • 203
        MASKED:
        PAINTED & MASKING REMOVED:
        • Paul S.
          • October 30, 2015
          • 203
          REASSEMBLED WITH NEW REPRO CENTER CAPS:
          The center caps are made by Trim Parts, who must have purchased the original tooling, as the caps are indistinguishable from my originals.
          Anyways, one down, three more to go!
          - Paul
          • Leif A.
            • September 1, 1997
            • 3568
            Attention to detail is self evident. Great job and well worth the time spent. Kudos.
            Leif
            • Wes S.
              • June 1, 1982
              • 196
              Are You going to start doing this as a part time job. What kind of tape di you use for the ribs?
              It looks like the General made it. Nice job.
              Wes
              • Gary J.
                • April 1, 1980
                • 1225
                Looks like fine line tape for the ribs
                • Paul S.
                  • October 30, 2015
                  • 203
                  It is 3M vinyl pinstriping tape. I used a leather-cutting tool to cut the ends into the correct rounded shape before applying it.
                  • Wes S.
                    • June 1, 1982
                    • 196
                    Thank You. It did a great job.
                    • Tim G.
                      • March 1, 1990
                      • 1334
                      Wow, those look beautiful. The PO2 option looks beautiful on Corvettes, such a classy appearance.
                      • Bob I.
                        • November 9, 2006
                        • 265
                        • Paul S.
                          • October 30, 2015
                          • 203
                          Luckily, my centers were in good shape and just needed thorough cleaning and polishing (on the fin edges). If I would have had to paint them, I probably would have just painted the entire fin area and then removed the paint from the fin edges afterward with a rag and a little bit of lacquer thinner. (I used semi-gloss black lacquer paint.)
                          • Bob W.
                            • December 1, 1977
                            • 786
                            Paul, super job they look like brand new caps. In your first post you said you removed the dents how? I can not find a way to get to them from the back side. Also where in Pa do you live as I'am from the North east part of the state.
                            • Jeff P.
                              • August 1, 1989
                              • 797
                              Very nice job.
                              68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
                              2014 Arctic White Z51 Vert. (Wifes)
