If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
To do this from a 64-7 booster, you would need the LIC bracket kit, to restamp the flange with correct number and then bright zinc versus yellow chromate the booster?
Ronald, there is a difference in the 63 vette/pass one and the 64-67 booster. The 63 vacuum port is on the lLH (driver) side where the 64-67 is on the RH (pass) side. So if you do restamp you can see it is not correct for 1963.
