If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Any suggestions on how to achieve this black appearance?
looking at some pervious posts on this subject, it seems there is a question as to whether the black rust inhibitor is indeed correct looking at my 65 springs, I do not see any evidence of a coating.
Per Chev. Engineering print: "Spray or dip with Lucas Rustproof #635 compound or equivalent for rust prevention (mix 7 parts of water with 1 part rust proof compound)
Here is my 2 cents. Like the prior replies, I believe that they were natural cast steel. I would recommend that if you do leave them natural, put a protective oil on them to minimize rust such as Pre-Lube 6. No matter how well you store your car, corrosion is inevitable and you may have to repeat your efforts a couple times per year.
