1957 lower rear fender splash shields
  • Dan P.
    • December 1, 1990
    • 683
    Were the bolts that hold the splash shields to frame recess hex head with flat washers. Or Clutch head .
  • Todd H.
    • 118
    Re: 1957 lower rear fender splash shields
    Dan,
    I don't believe mine have ever been off. They are hex head with the ridge around the edge of the head. I don't see washers under any of them.
    • Mike M.
      • June 1, 1974
      • 8331
      all three of our 57's utilize clutch head machine screws , except the two fasteners that secure the splash shield to the frame which are recessed hex head bolts with a "M" embossed on their heads. all three 57's have been apart so i can't be sure the clutch heads are correct. i did the first 57 back in the late 80's and was compulsive about using its original fasteners. the 2nd 57 was a total wreck when i restored it in the mid 2000's.i probably used the first 57 as a template to restore # 2 57. the last 57 wasn't restored by me, but rather by dick robinson. the AIM, section 11, page 2 illustrates the various fasteners involved. good luck . mike
      • Dan P.
        • December 1, 1990
        • 683
        Thanks for all the help
        • Dan P.
          • December 1, 1990
          • 683
          Bill Conrad was kind enough to send me pictures of his ordinal survivor 1957 Looks like no slots and and no washers .Recessed bolts look like the Circle C.
          • Mike M.
            • June 1, 1974
            • 8331
            on vin 555 the alpha character within the circle is a "M". mike
            • Todd H.
              • 118
