Question on 1966 Overflow Hose Straps-Radiator To Overflow Tank - NCRS Discussion Boards
  • Larry E.
    • 1701
    Have question on the above. Service Manual and Assembly Manual show 3 tie straps on this hose. 2 running parallel
    with front fender and one close to the radiator running parallel with it. My 66 is pretty well stone stock and shows no
    holes for the strap closest to the radiator. It only has 2 straps. Car is a 66 base engine with no A/C. Which is correct>
    2 or 3 straps?? Thanks-Larry P.S. Judging Manual is no help
    Larry
    LT1 in a 1LE -- One of 134
  • Leif A.
    • August 31, 1997
    • 3654
    Re: Question on 1966 Overflow Hose Straps-Radiator To Overflow Tank
    Larry,
    See if you have a hole adjacent to your hood support in the inner well...see picture.
    Leif
    • Larry E.
      • 1701
      Originally posted by Leif Anderson (29632)
      Larry,
      Leif:Thanks for reply. My hose is routed just like your picture indicates but>NO HOLE IN INNER WELL. Anybody else??
      Thanks-Larry
      Larry
      • Larry M.
        • January 1, 1992
        • 2702
        Agree with Leif...........there should be three (3).
        Larry
