If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
I have always used Eastwood Chassis Black, ( Original Chassis Black). They have different levels of the stuff. The Original is the closest to the factory paint. The underside of the hood should be a flat black.
Eastwood Chassis Black is a satin gloss..........which I believe is correct. However, semigloss can also be used, knowing it will degrade to a more satin finish with time........as car build occurs.
