If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Ran across this engine recently. I has been sitting in it's current location sine at least 1991. I have no reason to believe that it is not original, but your thoughts?
