60 Door Handle - NCRS Discussion Boards
60 Door Handle
  • Don H.
    • December 1, 1981
    • 1498
    60 Door Handle
    I have had the push button & spring retainer for the outside door handle come loose twice. I can't find any documentation in the service manuals about the assembly. It appears to simply be a "friction" fit so possibly I should apply some glue to retain it. Anyone have experience or suggestions? Thanks!
  • Mike E.
    • February 28, 1975
    • 5148
    Re: 60 Door Handle
    Don,
    I am guessing that those are typical-fit reproduction parts. There is a groove in the chrome part behind that pictured lip that the black piece twists into, but the fit is incorrect and the black piece, as you have found, because it is spring-loaded, ends up coming out. The correct original black piece was originally zinc plated, and the originals fit tightly but didn't come out of the chrome piece without twisting back off. Is your black piece original or repro? Seems to me that my original piece twisted extremely tightly into the repro chrome. You might try an original if that's a repro. Have you tried gently squeezing the lips of the chrome piece together. Otherwise, you might try adhering the two, but no guarantee that it will work. Good luck.
    Mike
    • Don H.
      • December 1, 1981
      • 1498
      Re: 60 Door Handle
      Hi Mike,
      Those are all original parts - I painted the twist in part after removing rust. It looks like I will have to add some type of adhesive. Thanks for the reply. Don H.
      • Keith R.
        • August 31, 2001
        • 675
        Re: 60 Door Handle
        I had the same problem and ran some solder in the groove which tightened things up.
        Keith MacRae
        NCRS #36692
        New Mexico Chapter
        1960 290HP FI
        2013 427 Convertible
        Shade tree mechanic and
        B-52 pilot extraordinaire
