If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Looking for a picture of a big block 67' oil pressure line. This line has 2 spirals in it and I'm wonder if the spirals are up fairly high just above the master cylinder?
