The 1955 Corvette parts manual says the casting numbers for 1953 - 1955 Vette front wheel cylinders are 5458021 & 5458022. Nobody I know has heard of these. Instead, it seems the 5453821 and 5453822 castings are generally accepted as correct for these years. Can anyone comment on this? I noticed the 1957 parts manual uses the 821 & 822 numbers as correct. Thanks!
Front Wheel Cylinder for '53 -55'?
Tags: None
- Top
Re: Front Wheel Cylinder for '53 -55'?
The '57 parts manual also shows in the Parts History Section that PN 5453817 (cast 5458021) changed 1-1-57 and should now use PN 5455479 (cast 5453822) in addition: PN 5453818 (cast 5458022) changed 10-1-56 and should now use PN 5455478 (cast 5453821).
I do not know how many friends you have but in this case I would trust the GM Parts Catalog as being correct.- Top
I do not know how many friends you have but in this case I would trust the GM Parts Catalog as being correct.Last edited by John S.; October 28, 2018, 01:50 AM.- Top
John, This is the clip from the 1955 Corvette Parts Manual I have. Is there more than one version of this guide published?Attached Files- Top
As I said before, get a 1955 Chevrolet Parts Catalog and you will see that the 55 Corvette Manual has the wrong casting numbers. Before I wrote the other post I also checked the original cylinder from my 55 and they were 821 and 822.- Top
Thanks John, I also have a discrepancy with the Steering Knuckle Support 6.023 between my car and the parts manual. Can you check your '55 for this number?- Top
The part in the picture is not a support, it is a arm 6.103. #3706019 and #3706020- Top
