'66 Thermostat Housing - NCRS Discussion Boards
  • Rob M.
    • April 30, 2003
    • 657
    All,
    According the JG, the thermostat housing for a '66/300 horse motor should be GM#3877660. They state that the part number was "typically" cast onto the mounting flange and has a recessed web area on each side of the two attaching bolts. So, here is a photo of the one pulled from my engine some time ago. I would like to know from those who may know if this is likely original/correct or if it is likely a later service replacement as the configuration differs from what the JG shows. Thank you in advance for your insight.
    Cheers
    Rob
    '66 327/300 Regional Top Flt
    '08 6 speed coupe
  • Keith B.
    • September 15, 2014
    • 1604
    Re: '66 Thermostat Housing
    typical of 68 and up
    • Rob M.
      • April 30, 2003
      • 657
      Thank you for the response.
      Rob
      '08 6 speed coupe
      • Rob M.
        • April 30, 2003
        • 657
        In looking at the part offered by LIC, it is very similar to mine as far as the part number location. But, it also has the recessed area like the one pictured in the JG. So, is it wrong too?
        Rob
        '08 6 speed coupe
        • Keith B.
          • 1604
          There were several design changes over the years and for diffreant applactions on Corvettes and Passenger cars and trucks. The one you want will have the numbers on the flange and a eyelet for a spring on the base. They are everywhere for sale on the net.
          • Joe R.
            • July 31, 1976
            • 4552
            Here is another 660 that came from a 66 also. The word TYPICAL is used in the judging manual to allow a judge with basically no knowledge of what he is doing to take points away because of his ignorance.
            JR
            • Keith B.
              • 1604
              found this in a search on here.
              National Corvette Restorers Society Oklahoma Chapter. Corvette enthusiasts from Oklahoma and surrounding states who join together to celebrate and enjoy the Chevrolet Corvette. The Oklahoma NCRS Chapter members hold regular monthly meetings to share our interest in the Corvette. This is a place to find like minded individuals to support your passion, whether you are driving a brand new Corvette, restoring an old Corvette or just trying to relive a past Corvette experience.
              • Rob M.
                • April 30, 2003
                • 657
                Thanks Keith for the article. It was interesting to see so many variants of the same housing. Mine is very much like Joe's other than the mine has the part number flipped and also has the 1C and triangle boss on the neck. The spring hole is also there. I would love to see a bowtie car/one owner around my build date to see what's there. I just know why a prior owner would change that?
                Rob
                '08 6 speed coupe
