Holley 4160 primary fuel bowl replacement - NCRS Discussion Boards
  • Jeffrey B.
    • January 1, 2006
    • 82
    I think fuel maybe leaking past the O rings in my fuel bowls causing flooding. When I pulled the bowls and removed the needle and seat assemblies, I notice some pitting in the area when the O ring would normally create a seal.
    I can find a new replacement bowl for the secondary side with an external adjustable float capability, but when I try to find one on line for the primary side I can only find a bowl for a marine application that does not have the external adjustable float capability.
    Has anybody used this style of bowl successfully which would not be the original design?
    I'm concerned that if I buy a used bowl on line it will likely have the pitting inside where the O ring seals so I would have bought basically a junk unit.
    Feedback on my post would be greatly appriciated.
    Jeff Bailey
    • 43281
    Re: Holley 4160 primary fuel bowl replacement
    Jeff Bailey
    Jeff------
    What you describe is exactly what you may very well experience with a used carburetor part. I'd want to use a NEW float bowl, exactly correct, or not. I'd contact Holley about a new fuel bowl. Holley does reproduce these carburetors so the parts must be available.
    • Jeffrey B.
      • January 1, 2006
      • 82
        • 43281
        John,
        I had a conversation by phone this afternoon with Holley tech support and based on what I was told the original style fuel bowl I need #34R-4424-B that a stock Corvette steel fuel line treads into is no longer available. The only bowl We discussed that they can provide is actually for a marine application and does not have external float adjustment capability and I don’t believe it is vented. They show only this style bowl on line that would fit my OEM carb that stock hard line would thread into.
        Appriciate your feedback.
        Jeff Bailey
        Jeff------
        This must be a case of Holley manufacturing the parts but not selling them separately from the reproduction carbs. Holley reproduces the following 4160 models: 3367, 3370, 3810, and 3811.
        • Greg W.
          • February 26, 2015
          • 141
          Jeff, I may have a primary bowl for you I do not need. In good shape. PM me and we will talk
          Greg
          • Greg W.
            • February 26, 2015
            • 141
            Jeff , I sent you back a message but not sure I did it correct
            Greg
