56-57 cooling fan?
  • Troy P.
    • February 1, 1989
    • 1279
    56-57 cooling fan?
    I have a 7 1/4" four blade fan that has curved tips. The 55 fan is that size but has flat tips. I'm wondering if what I have is a 56-57 fan.
    Can anyone shed light on what this fan might fit?
  • Gary C.
    Administrator
    • October 1, 1982
    • 17395
    Re: 56-57 cooling fan?
    Passenger car. '57 Corvette curved tip fans are 17 inches
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Troy P.
      • February 1, 1989
      • 1279
      Gary are you sure the 57 Corvette fan is exactly 17" and not a nominal 17"? It seems unlikely that GM would have bothered to make an identical fan but only 1/4" different in diameter for their passenger cars. Other than the 1/4" size difference is there anything else that make it appear as a passenger car unit?
      The 55 Corvette fan is exactly 17 1/4" with straight tips. But the parts book lists it as 17". Makes me suspect the 56-57 fan is listed as 17" and is really 17 1/4".
      You would think if a 17 1/4" fan worked in 55 that it would also fit in 56 and 57.
      Of course that is all logic.
      • Todd H.
        • 118
        The fan from my '57, which I have good reason the believe is original, has curved tips and measures 17 inches.
        • Troy P.
          • February 1, 1989
          • 1279
          Thanks for your info. Interesting that Chevy would have fans made only 1/4" different in blade length.
          • Kent S.
            • February 1, 1993
            • 198
            Different suppliers maybe?
            • Troy P.
              • February 1, 1989
              • 1279
              An 1/8" different on each blade would not create interference with the fan shroud. Shrouds are basically the same for 55, 56, and 57, with some differences, and 17 1/4" clears the 55 fan shroud.
              • Gary C.
                Administrator
                • October 1, 1982
                • 17395
                Troy,
                Kent beat me to the photo. Finally found a spare '57 curved time fan and it measures end-to-end 17 inches spot on.
                Part number 3735314 blueprint length tolerance is minimal.
                Gary
                NCRS Texas Chapter
                • Troy P.
                  • February 1, 1989
                  • 1279
                  55 part per the December 55 Corvette P&A is:
                  Blade Assembly, Fan
                  '55-V-8 (17 dia. 4 blades) 3712555*
                  * indicates the part is used on other vehicles
                  (Note that it says 17" whereas it measures 17 1/4" and that is the dimension specified in the 53-55 TIMJG. That extra 1/4" cost some supplier money.)
                  The 55 passenger car 6 cyl and V-8 fan is 3704803. So it is unclear what other vehicles the 55 Corvette fan was used on.
