1963 half shaft bolts - NCRS Discussion Boards
  • Jeff C.
    • September 30, 1997
    • 233
    The JM states that in beginning in late 1963 the half shaft is bolted to the rear spindle flange and the bolts are secured with steel French locks. It does not address early (nov 1962) cars. So are lock washers used or nothing?
  • Loren L.
    • April 30, 1976
    • 4104
    Re: 1963 half shaft bolts
    Per the AIM indications, lock washers were used until o/a April 1, 1963.
    • Marco H.
      • March 1, 2002
      • 218
      Jeff,
      Observing original cars, the french locks were not used in 63, or only VERY late. 20939 still had no french locks. The AIM 4-1-63 revision appears to not affect production for a long time. Most cars are observed with lock washers under the bolt heads, however some had no washers at all. More observations of late cars are necessary to pinpoint the introduction of french locks.
      Hope this helps, Marco
