If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Appreciate if someone could confirm (or remember) if the original spark plug wire sets were resistor wire sets. My C2 is a 327 cu 340HP car). The original plugs were AC44 non-resistive as what I remember and what is see is various catalogs.
Rich
Packard TVRS resistor wires were used for most C2 cars. These had a carbon/graphite core. Exceptions probably L88 and perhaps a few other specialized applications.
Solid core wire (like Packard 440 wire) was not used by the factory on these C2 cars.
Larry
Larry-----
I agree.
By the way, I should have mentioned, resistor spark plugs began for the 1969 model year. However, carbon core ignition wires go back to the vast majority of Corvette applications right back to the days of 6 cylinders.
Reason: add second paragraph
