1955 ignition shielding capacitor - NCRS Discussion Boards
  • Ronald R.
    • May 31, 1989
    • 670
    Is this capacitor available and what does it look like? thanks for any help Ronnie
  • John S.
    • July 29, 2009
    • 640
    Re: 1955 ignition shielding capacitor
    shielding, regulator, regulator replacement, distributor
    • Ronald R.
      • May 31, 1989
      • 670
      I have 2 like the second from the left, for the voltage regulator and 3 of the replacement that are extra. I need both the outside units. These pictures will help me in my search!!! thanks you John! Ronnie
      • John S.
        • July 29, 2009
        • 640
        if you have no luck locating the two outer units I could probably let go of a set. The shielding capacitor was only sold with the shielding, so I do not know if anyone would sell a capacitor separately.
        • Ronald R.
          • May 31, 1989
          • 670
          My mechanic came up with this at Carlilse, looks the same except the bracket, mine is two screws on mounting brkt???
          thanks Ronnie
          • John S.
            • July 29, 2009
            • 640
            there are two brackets(one and two screw) that were commonly used with that capacitor. The corvette uses the one screw, so if you want to use that bracket cut it in half.
            • Ronald R.
              • May 31, 1989
              • 670
              ok thanks how much for the other alone? Ronnie
              • Joe R.
                • July 31, 1976
                • 4551
                Maybe this pic will help you.
                JR
                • Ronald R.
                  • May 31, 1989
                  • 670
                  I need pic of the one that is on the side of the distributor? Thanks
                  • Joe R.
                    • July 31, 1976
                    • 4551
                    OK, how about this one!
                    JR
                    • Ronald R.
                      • May 31, 1989
                      • 670
                      that is it do you have a pic from the other side? thanks ronnie
