If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Did GM use a gasket or sealant when installing a new car exhaust system? Are replacement pipes and mufflers a advantage to use a sealer and what type?
You didn't mention the year C3 you are interested in, but your reference to a cat (I presume not a feline) would indicate a later C3.
Your AIM for whatever year you are interested in should show you if an exhaust pipe sealant was used. The sealant is called out in the 1968-72 AIMs and there was sealant present at the junction of the front to rear pipes on my 1970 when I first disassembled the system.
I found the sealant at one place on the cross over but nothing else in the aims. Question? I did not know the c4 (93) had a aims
To my knowledge there are no AIMs as we know them from earlier Corvettes for C4s. There are, however, product description manuals. These are not sold to enthusiasts and I have no idea if they contain the information you are looking for.
