Mystery Bolts from Engine that was Pulled_Can Someone ID?? - NCRS Discussion Boards
  • Paul C.
    • November 12, 2007
    • 511
    Had someone pull my engine at the bell housing and am cleaning all the bolts. I have 6 x 3/8 x 1 inch black phosphate hex head bolts with sb grade 5 head markings. The have threads halfway up the bolt. Engine is at the rebuilder and he can't figure out where they came from when pulling the engine. The guy who pulled the engine had them labeled intake bolts--that I know is incorrect. Can someone help me solve the mstery?
  • Michael L.
    • December 15, 2006
    • 1416
    Re: Mystery Bolts from Engine that was Pulled_Can Someone ID??
    Can you tell me what year/engine they're from? What options? What tranny? thoughts that come to mind are Pressure plate to flywheel bolts, which would also explain why the builder can't figure out where they go, since bolting on the pressure plate usually isn't part of a rebuild. They're are six of those bolts and that's the right thread/length IIRC.
    Mike
      • 6957
      Paul , I agree with Mike They appear to the bolts that hold the pressure plate to flywheel.
      • David B.
        • April 1, 2000
        • 41
        I have things apart at the moment, so I just checked my baggie of pressure plate bolts. The dimensions look similar, but I've got grade 8s (which I assume are correct), not grade 5s.
        Is it possible they're from the side motor mounts? (I have a C1, so don't know anything about those).
        • Paul C.
          • November 12, 2007
          • 511
          It is a 1971 LT-1, 4-speed.
          Here's a picture of the engine out of the car.
          • Michael L.
            • December 15, 2006
            • 1416
            Motor mount bolts are another def possibility.
            • Michael L.
              • December 15, 2006
              • 1416
              I'm headed to my shop in a bit I will check my pressure plate bolts to see what they are.
              • Patrick B.
                • August 31, 1985
                • 2013
                The pressure plate to flywheel bolts shoud be grade 8 and only partially threaded. That is what you have.
                  • 43281
                  David-------
                  Motor mount bolts are all thread. These bolts would not even work for that application since the un-threaded shank is too long. In other words, you'd never be able to tighten them against the motor mount. I'm pretty confident these are pressure plate-to-flywheel bolts. Some of these are grade 5 (3 lines).
                  • David B.
                    • April 1, 2000
                    • 41
                    ...and that's why I shouldn't "assume". Thanks, Joe.
                      • 6957
                      Paul check the head marks on both sets of bolts. this may give some in site on the bolts of that era.
                      • Paul C.
                        • November 12, 2007
                        • 511
                        The guy who pulled the engine didn't remove the clutch or flywheel and the motor mounts are still on the engine. Now I'm really at a loss for where they came from.
                        • Stephen L.
                          • May 31, 1984
                          • 3162
                          Bellhousing to block???????????????????????
                          • Thomas J.
                            • March 10, 2017
                            • 22
                            I have two 71 with 4 speeds pulled bolt from each bell housing bolt is 1 1/4 long threaded all the way grade 8 sounds like what you have are bell housing bolts someone changed out
                            • Paul C.
                              • November 12, 2007
                              • 511
                              The bell housing bolts are threaded the entire length and I have those in a bag. I'm stumped.
