1971 Lower Ignition Shield Mounting Brackets GM Parts Numbers - NCRS Discussion Boards
  • Paul C.
    • November 12, 2007
    • 511
    I think one bracket is GM #3819757 and the other is GM #3819759. Are the brackets numbers the same numbers for both sides. Is there a difference between the left side and right side brackets or are they the same. Thanks as always.
  • Paul C.
    • November 12, 2007
    • 511
    Re: 1971 Lower Ignition Shield Mounting Brackets GM Parts Numbers
    Figured it out. The other 2 brackets are the same and are GM #3819758.
      • 43288
      Paul-----
      If you're talking about the spark plug HEAT SHIELDS, it's like this:
      left front and right rear= GM #3917664
      right front and left rear= GM #3817657
      As far as the RF SHIELD SUPPORTS go, it's like this:
      left side, rear:
      rear position= GM #3819758
      forward position= GM #3819759
      right side rear:
      forward position= GM #3819757
      Of course, no RF shields were used at the left or right front for 1971, so no suppports are required.
