1954 Family Corvette
  • Tony R.
    • April 20, 2017
    • 201
    I am in the initial research phase on this. My dad has a 1954 corvette that he and his brother bought together in about 1964. When I was younger, my dad, brother, and I took it to some car shows. Later on, my dad bought his brother out of his half. There is some nostalgic/sentimental attachment to this car. I have always had a soft spot for this car, and lately I have been considering restoring it. I could do some myself, but not the motor, transmission, or body (what's left, you might ask).
    A first step in the decision-making process is to document the car. I have attached some photos and typed below some numbers. Any advice on the following questions would be VERY welcome. If I were to restore this, I would actually want to be able to drive it, but would likely do a body-off restoration. I would want to do a very nice job, but would not be trailering the car to national shows or anything. By driving, I mean occasional weekend drives or just around town. Not across the country.
    Questions:
    -How hard is it to get a Corvette head for a 1954 and does anyone have any idea how much that would cost?
    -How can I obtain some guidance on what this car is worth as it sets or if I clean it up and get the motor running? One possibility is selling this car and buying some other Corvette - maybe late 50s or early 60s.
    -Any advice on obtaining some guidance on what it would cost in the area of bodywork and paint? I would want to have a very good job done in terms of body work, and then a nice job on paint. Paint can always be re-done to any level, but the bodywork is always under there.
    Some Numbers (as best I can make them out):
    VIN - E54S002040
    Engine Stamp - 0454948F54YG
    Carbs - Carter 2066SA
    Trans - need to clean it up and take a better picture
    Rear-end - need to clean it up and take a better picture
    Cylinder Head - 3836241* (not quite - see saga below)
    Cylinder Head: The head was determined to be cracked when I was a kid. It was repaired by a machine shop, but somehow they "lost" it. They replaced it with another head that I can only assume was not a Corvette head, because they said they "put the right number on it." My dad probably would have pursued them harder on it, but at that time he had some other, bigger, things to worry about at that time.
  • Tony R.
    • April 20, 2017
    • 201
    Re: 1954 Family Corvette
    Photos of the cylinder head. Again, the number was likely changed and I see the temperature sending unit adaptor as well.
      • 11535
      Two questions -
      Does it run?
      Was it ever painted?
      Patrick
      • Tony R.
        • April 20, 2017
        • 201
        My dad had it repainted and had the engine and transmission done (bearings, rings, etc.) back in the 60s or early 70s. At that time he had the interior upholstery redone as well. It hasn't been started or run since the late 80s. But to answer what I assume is the implied question, no it is not a completely original car in the shape it rolled off of the assembly line.
          • 11535
          I knew it wasn't in assembly-line condition based on the photographs.
          I'd be tempted to get it running and driving, and then use it like that for a couple of years or more. However, that's just me, and I don't mind doing that type of work. It's a neat old car. As 54s are not worth as much as 53s or 55s, yet cost just as much to restore, there is the chance of getting upside-down with regard to cost.
          • Chris S.
            • January 1, 2000
            • 1052
            241 is the correct head for the car.
            Nice car and looks very complete
            A correct 241 head are expensive 3k and up
            Do you have a photo of the head
            1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
            Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
            1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
            1957 Corvette - FI 3 sp - Black and Silver
            • Chris S.
              • January 1, 2000
              • 1052
              Tony
              on the paint - the body would need stripped then checked for damage
              I like to blast all of the bodies I do
              I have 3 1954's bodies here
              You have several desireable and valuable parts
              Gas Cap, radio , hub caps, distributor, side draft air cleaners......
              Do you have the side curtains.
              • Tony R.
                • April 20, 2017
                • 201
                Chris S. - By side curtains, do you mean the windows for the doors? If you do, then yes they are there.
                • Tony R.
                  • April 20, 2017
                  • 201
                  Chris S - No photo of the head, other than the one of the serial and the temperature sending unit. I believe that I will pull the valve cover and look for other information to narrow down what the head may have come off of. A limiting factor may be that some of the casting numbers (the ones that should end in 241 for this car) were modified by the machine shop way back. In any event, it is not the right head.
                  • Chris S.
                    • January 1, 2000
                    • 1052
                    If you look at the temp sender hole - if there is an adapter used then prob not a 241 head and is a passenger car or truck head.
                    • Tony R.
                      • April 20, 2017
                      • 201
                      Thank you very much to those who have chimed in. Any suggestions from anyone on the following for this car?
                      -Advice on obtaining some guidance on what this car is worth as it sets, or just cleaned up and running?
                      Thanks much!
                      • Keith W.
                        • July 1, 1998
                        • 375
                        Tony for another source of info and help you could try the SACC boys as well - they live and breath solid axles the majority are NCRS members too.
                        for what it's worth try and get her roadworthy for a couple of years - just enjoy her - Keith
                          • 11535
                          Thanks much!
                          Hagerty's value guide places it about $35000. My guess is that an inspection of the frame might decrease that if it's crusty.
                          I disagree on your body/paint thoughts. 90% of your money and time goes into the prep of any paint job. What you apply on top is peanuts compared to what you've spent to get there. You also have to determine if you want it to appear original, concours, or a driver with regard to body and paint. That end decision will affect your cost, and it's costly to change halfway through the process.
                          • Tony R.
                            • April 20, 2017
                            • 201
                            Thank you all for your input, thoughts, and information. I am still gathering information on this car and thinking through the direction to take. I will say that I am astounded at the level of information available out there on this site!
                            • Richard K.
                              • April 1, 1988
                              • 207
                              Tony,
                              IMHO, you would regret selling this car. You've said "I've always had a soft spot for this car". No, it will never have the value of a '53, or a V8 '55, but it is still a damn unique vehicle, and the beginning of US sports car history. If it were my good fortune to own that car, I would make it road worthy, as clean as I could make it, and enjoy all the conversations that I would ignite at as many car cruises as I could attend.
                              Best of luck with whatever direction you take.
