If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
I have come across 60's vintage AC 45S plugs with fluted tips. Were these tips an idea or gimmick that did not work in the 60's? Should they be avoided ?
