If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
I recently pulled my c2 4speed and found that the "serial numbers" don't match
can someone help me with the deciphering so I can see what year it came out of?
The casting code 3851325 is from a 1964 or 1965 vehicle. Could be an M20 or M21. The side cover should have casting #3831707, and the tail housing should have casting 3846429 (64 and early 65) or 3857584 (late 65)
So the assembly code as Dave indicated would be January 28, 1964 or 1965.
I believe the J185273 is actually the VIN of the vehicle the transmission came from. What I found in one of Alan Clovin's books is that the J designated the Janesville Wisconsin plant. That plant built passenger cars, so your transmission likely came from a passenger car. However, if all the castings are correct as I indicated above, the transmission should be correct for a 1965 corvette, just didn't originate in a corvette.
Don Harris
