1972 LT1 Aluminum valve cover bolt torque? - NCRS Discussion Boards
  • Gary S.
    • July 31, 1992
    • 1633
    Maybe I am perpetually tired/slow but my searching here, the AIM, and Corvette Service Guide turns up lots of torque values except for valve cover bolts. Googling turns up numbers from various forums and technical sites of 2-4 foot pounds or 24-48 in-lbs. My memory has 36 in-lbs but I can't find it.
    Btw, based on a recently posted question concerning oil leakage, I bought Fel-pro 1604 valve cover gaskets (thank you Joe L.) and yes they are thicker but if they stop leaks I'm ok. When torquing to 36 in-lbs, does gasket compression result in a fair amount of torquing beyond "that feels about right". I ask because, once I tightened them by hand, I put my inch-pound torque gauge on it, set to 36 in-lb, and turned until I was doubting myself until it finally clicked. I assumed that the cork-composite gasket was compressing. Wrong assumption or correct?
    thank you as always.
  • Mark E.
    • April 1, 1993
    • 4607
    Re: 1972 LT1 Aluminum valve cover bolt torque?
    I've always used the "that feels about right" method, and probably err on the light side. If they leak after a heat cycle, I then tighten a bit more. Check periodically and repeat as needed.
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • Gary S.
      • July 31, 1992
      • 1633
      Mark,
      I have always done the same with valve covers. However, I am trying to turn over a new leaf and rid myself of bad habits as well as curtail some leaks. the leaky cork valve cover gaskets were most likely my leak source but I will soon find out. My googling has revealed that many folks do it your way.
      Right now I am re-doing brakes now that the valve covers are back on (torqued to 36 in-lbs) and I may dig into the steering to fix my always on door buzzer whenever the door is opened. I fixed it perhaps 10 years ago so it is easy enough to do. So, it won't be a while before I get the engine running.
        • 43272
        Originally posted by Gary Schisler (21316)
        Mark,
        Gary------
        I have no information that the torque rating for the aluminum valve cover bolts is any different than that for the standard steel cover bolts. That torque is 55 lb/inches.
        • Gary S.
          • July 31, 1992
          • 1633
          Hmmm, that is 4.6 ft-lbs which is on the high side of what I recall but still pretty light. What I wound up doing was to undo the bolts and put my 1/4" drive handle with the socket on it and did it "wrist tight". I then checked it with the torque wrench and it was at 4.
          Thank you. I will do that number.
          • Dan A.
            • February 1, 2004
            • 212
            Gary,
            Were you able to use the original valve cover bolts with these gaskets?
            Thanks.
            • Gary S.
              • July 31, 1992
              • 1633
              Originally posted by Dan Agnew (41438)
              Gary,
              Thanks.
              Dan,
              Yes I was. My bolts original. And I'm guessing that they're about 1 and 1/8 inch long. The gaskets are only perhaps one sixteenth of an inch taller maybe one eighth? The bolts fit easily
              • Dan A.
                • February 1, 2004
                • 212
                Thank you very much!
                • Edward B.
                  • January 1, 1988
                  • 537
                  In 1966, Justice Potter Stewart remarked about obscenity, "I know it when I see it." Here we are talking about 'hand tight,' and I know it when I feel it.
                  • Gary S.
                    • July 31, 1992
                    • 1633
                    What can I say! In full disclosure, I wasn't anything more than lucky with that technique.
                    • Jim T.
                      • March 1, 1993
                      • 5351
                      Gary my 1985 Corvette GM service manual has a torque of 50 INCH POUNDS for the 1985's valve cover bolts. I don't remember seeing torque in my 1970's GM service manual so I use 50 INCH POUNDS.
                      • Gary S.
                        • July 31, 1992
                        • 1633
                        Thank you Jim. I have found lots of internet comments but nothing in print. I am good to go now and will observe for leaks once I get it all out back together. I.went through all of my GM reprint manuals plus aftermarket manuals. Nada.
                        Gary
                        • Richard K.
                          • April 1, 1988
                          • 207
                          I watch a lot of Velocity TV programs, and I've noticed that the restoration/custom guys on these shows rarely use a torque wrench. I assume they use the torque "system" that I read or heard about many years ago called "mechanic's torque", which is, turn the screw/bolt until it seats and then give it 1/4 more turn. I almost always use a torque wrench, but I've often wondered how far off the "mechanic's torque" torque could be. In the case of compressing gaskets, would it work that well at all?
                            • 43272
                            Gary
                            Gary------
                            It's in the GM factory service manuals in the engine section of the "bolt torque" tables at the rear of the manuals. However, there is no distinction made between the type of valve covers. That means that the torque specified is the same regardless of type of valve covers.
                            • Gary S.
                              • July 31, 1992
                              • 1633
                              I'm not home now but the Service Manual was the first place I turned to before I started typing. Lots of torque values at the back but I really don't recall seeing anything for the valve covers. I will look again. regardless they're now sitting at about 45 to 48 inch poundsmk
