57 balancer question?? - NCRS Discussion Boards
  • John R.
    • November 1, 2005
    • 433
    Soliciting some help on confirming which balancer to use on a very late 57 with 245 hsp? I have an old Judging manual and it is a bit unclear, I think. Perhaps the new judging manual is a bit more clear.
    Should it be the 3/8" or 1/2" riveted or 991 pulley bolted onto the balancer? Thanks in advance for the clarification.
  • Joseph L.
    • July 26, 2012
    • 162
    Re: 57 balancer question??
    Hi John
    I have a 57 270HP and am looking for information on the exact configuration for that balancer too.
    The new JM show a picture of the "riveted crankcase pulley" with balancer. That balancer has a small step protruding from the front, where the ID of the pulley is located by the OD of this step. The OD appears to be about 2". There is also a photo of the bolt on pulley for the 283HP engine that shows the PN "3742991 GM."
    The 1957 AIM (page 579 1.01) shows this pulley PN 3742991 "used with high lift cam."
    There is also a table in the JM that identifies 245, 250, 270 HP using a 1/2" wide pulley riveted to the balancer. All others use a 3/8" wide pulley riveted to the balancer.
    The 1958-60 JM shows a photo of the 58-59 balancer PN 3760584, and 'early 58 cars had the 3742991 pulley bolted to this balancer.' It does not have the small 2" OD step that is shown on the balancer in the 1956-7 JM. Also, it has no holes on the outer band. I have what appears to be a 3760584 balancer with no holes.
    We are both looking for the same balancer assembly.
    More specifically for both of our cars, is the correct configuration; the 3760584 balancer riveted to the 3742991 pulley? Does someone have a photo of that part or can comment on the configuration?
    Joe
    • John R.
      • November 1, 2005
      • 433
      Posted this a while ago. Would love to know the correct configuration on the balancer/pulley for a very late 245 hsp. Also, while we are at it, would I use the stepped waterpump pulley or not?
      • John R.
        • November 1, 2005
        • 433
        I see from researching, the 245hsp engine uses the 1/2 inch generator and waterpump (stepped) pulley. So that must mean the crank pulley is 1/2 too. This is a very late car assembled during the last couple days of production in late August 1957. Last piece of information I need is to confirm the configuration of the crank pulley and balancer. Is it the 1/2 inch pulley riveted to the balancer or 991 (1/2 inch) pulley bolted to the balancer?
        Thanks in advance to anyone who can help. Want to get this correct the first time
        • Gary C.
          Administrator
          • October 1, 1982
          • 17690
          John,
          Pulleys and balance applications are listed in the 1956-57 Judging Manual.
          Gary
          NCRS Texas Chapter
          https://www.ncrstexas.org/
          • John R.
            • November 1, 2005
            • 433
            Gary, thanks for the direction. Here is what the JM says. Not so clear, thus hoping someone can assist. Thank you.
            • Gary C.
              Administrator
              • October 1, 1982
              • 17690
              There's been two 56-7 Judging Manual revisions since that manual.
              Suggest, you purchase a new 56-7 JM. Lots more information and photos.
              Gary
              NCRS Texas Chapter
              • John R.
                • November 1, 2005
                • 433
                Gary, I will buy a new 57 JM when I get closer to getting serious about having this car judged. Who knows that may be never or 3 revisions to the JM by that time! Was hoping someone on this board could help a fellow member. Hope that is not too much to ask.
                • Perry M.
                  • January 1, 1977
                  • 325
                  it's not to much to ask. Somewhere in my unpacked files lies the information you need, I recently relocated and all my literature is still in boxes. I know from restoring my factory fuel injected 57 Nomad back in the 80's that you need a 1/2'' riveted pulley. All 245, 250, and 270 horse power engines used the 12'' riveted pulled. The water pump pulley was also 1/2'' wide and it was stepped. The generator pulley was also 1/2''. There was a difference in the 1/2'' generator pulleys. Original 57 pulleys had round spot welds on the face verses rectangular shaped spot welds. The 283 horsepower motors used the 991 bolt on pulley. All turboglide equipped passenger cars also used the 991 bolt on pulley. That's probably why they are easier to find than the riveted pulley because they were more prevalent. If you need a generator or water pump pulley, let me know. Perry
                  • Dan P.
                    • December 1, 1990
                    • 683
                    I will post one later. You can also find the balancer on trucks . I think Gary Pronesti has the balancer you need .
                    • Dan P.
                      • December 1, 1990
                      • 683
                      If remember correctly not all had the part number and some were stamped on the back side . There were also two styles of pulleys . I do not have a picture of the other style
                      • Mike M.
                        • May 31, 1974
                        • 8389
                        dan: I'd loose the bolt/thick washer retaining the balancer/pulley to crank snout for judging . regards, mike
                        • John R.
                          • November 1, 2005
                          • 433
                          Dan, thank you. Much appreciated.
                          • Dan P.
                            • December 1, 1990
                            • 683
                            I plan on it
                            • Darryl D.
                              • February 7, 2017
                              • 386
                              Gary
                              You know the answer so why can't you just tell him? NCRS always has their hand out to sell another JM
